lowlysoundtech's Avatar lowlysoundtech 2
2 Asked
2 Answered
0 Best
0
No one has voted on this question yet :(
2 years ago
Anyone know of an open source DMX platform?
Basically, either a schematic or board design that can take a dmx signal in and output controlled voltages to send to leds or servos.
Separate topics with commas, or by pressing return. Use the delete or backspace key to edit or remove existing topics.
You can leave an optional "tip" with Mahalo's virtual currency, Mahalo Dollars. If you are asking a difficult question that might require some research, or if you'd like a wide variety of feedback, a higher tip often leads to more answers to your question.
M$
What is Your Answer?
0
0
0
2
robertely's Avatar
robertely | 2 years ago
2
M$
lowlysoundtech | 2 years ago Report
I had glossed over this page in the past, but wasn't able to glean what I needed from it. I'm going to give it another look to see what else I need to receive DMX on the arduino. Thanks for your response!
BTW, and if anybody else reads this... I didn't mean to select no answer, i was using my droid to check this out on the train and bumped it accidentally. Sorry folks!
Report Abuse
Post Reply Cancel
1
xeracy's Avatar
xeracy | 2 years ago
2
enttec has a number of dmx solutions, including this Open Source (GPL) USB-DMX Dongle. It can be configured for input and output and they provide the schematic as well as a fully build device. there are a number of programming examples and programs both free and pay-for linked on that product page.
Look at the downloads page for a schematic and software/programming examples.
http://www.enttec.com/index.php?main_menu=Products&pn=70303&show=description&name=opendmxusb
images:
M$
Actually, I don't need to output DMX at all. That's the problem with just using an Arduino, I need to RECEIVE DMX....an end of the line device. I have a board that is essentially a shield for a different proto board, but the code for the arduino is a bit wonky, needs to be tweaked.
I have 13 different DMX LED lights that I already run with the Velleman and Freestyler and I need a strobe for a party coming up. I figured, I have a bunch of 1W LEDs and an Arduino.....I should be able to get a DMX strobe out of this. And if I'm not willing to drop the $150-250 for a strobe right now, I'm sure not going to drop another $60 just to buying something that I already have the parts to build myself.
xeracy's Avatar
xeracy | 2 years ago Report
60$ Assembled DMX dongle and a 3-to-5-pin turnaround is out of your budget? parts alone would be atleast $30, and then ya still gotta build it. The only benefit of this over your Velleman is the openness. What exactly is your application? It seems you need a micro controller that can output dmx, and not just a DMX controller..
xeracy's Avatar
This guy has done it: http://blog.wingedvictorydesign.com/2009/03/20/receive-dmx-512-with-an-arduino/
ALTERNATE: If you do have a few $ to throw around >> http://www.amazon.com/Chauvet-Mini-Flash-Strobe-Light/dp/B0002CZVG4
Chauvet Mini Strobes 15$ at guitar-center/etc. kick ass for the price. grab four and run them off a non-dim channel on your dimmer (I have dimmed them before and it wrecks havoc with the electronics).
I know this doesnt solve your problem, but a lot of time, when it come to production work, getting the effect is more important than how you do it.
Anecdotal(-ish) Story:
I spent hours stuffing the flash from a disposable camera into an old fashioned camera prop. While I did manage to get it to work, it wasn't bright enough to compete with stage lighting and also the recharge time on the capacitors was like 15-20 seconds, so it was useless for the one scene that it was needed for. We ended up using a stobe cap on a Source4. I wasted (wasnt really a waste, i learned a lot) a lot of production time on something that we could have been done easier and gotten a better effect.
I actually have a Velleman DMX interface at the moment, but need something that's 3 pin and a little cheaper. Alas, budgets.... thanks for your response though.
Report Abuse
Post Reply Cancel
0
omega's Avatar
omega | 2 years ago
2
I'm working on a project that involves some slightly funky DMX interfacing, and as part of the project I will be developing and selling modules that operate as the core. The module will be built on the same concept as my Xmega DIP adapters (http://omegacs.wordpress.com/2010/04/16/xmega-adapter-boards-for-breadboarding/), but include screw terminals for two DMX ports as well as a soft USB port for configuration. DMX interfacing software will be provided in source form, designed for as little overhead as possible (e.g. DMA doing most of the work).
The module exposes 28 I/O lines, half of which are analog, 2 of which have high-speed DAC's on them. I will also be releasing code that will do fast, efficient, high-resolution, and *patent-free* LED dimming outputs.
The main project is slated for completion by Fall 2010, so the modules will likely be available sometime this summer. Keep an eye on http://blog.omegacs.net/ for updates.
M$
omega's Avatar
omega | 2 years ago Report
Looks like between some domain reshuffling I've been doing to organize things, and answers.hackaday's linkification putting the parenthesis in the URL, it's a bit messed up. However, since then I've put up a blog post specific to this module:
http://blog.omegacs.net/2010/05/04/dmx-512-module-in-development/
I'll attach the shot of the mostly-completed PCB artwork here just in case.
The microcontroller runs at a maximum of 3.3V, and each pin can drive 20mA. I've ganged pins together to drive more in the past, but if you need to drive a stepper the intent is for this module to be placed on your own board (as if it were a standard 600mil 40-pin DIP chip itself) and wired up the appropriate drivers. The board should be able to drive 20mA LEDs directly, as long as they're common-anode, since the board can simply turn its current sink on or let the pin float: +5V -> Anode-LED-Cathode -> module.
As far as cost, the Xmega adapter board in the same class, which lacks the USB port, DMX drivers, and the screw connectors, is currently being sold (in preproduction quantities) for $15 assembled. The USB connector is ~$3-4, the 3x screw terminals are ~$1/ea, and the MAX13430 is ~$3.50/ea. That would bring the total to somewhere around $30-35 depending on various other factors.
I'll probably develop a non-USB, single-port version for simpler applications, which should shave most of $10 off the price of the current module.
http://omegacs.files.wordpress.com/2010/05/xmegaa4-dualdmx.png?w=449&h=177
I'd love to check out your project, but it appears your page is down. I have two questions though...
What kind of voltage/current can you output to an end component, such as LED or stepper or servo?
What would we be looking at cost wise? Is it just one board or a system of modules? Is it similar to the Propeller Project?
Report Abuse
Post Reply Cancel
0
xchurchx's Avatar
xchurchx | 2 years ago
2
Hey, your thread is number 3 on Google! :)
http://www.lmgtfy.com/?q=open+dmx+platform
I recommend the Arduino for entry-level ease and fun factor. I basically went the other direction and use an Arduino and piezo transducers to control a DMX lighting board via MIDI.
M$
Wow, that's pretty cool! I have an arduino and have searched for a workable DMX receiver solution for it, but for some reason, i dismissed this page, i just have to remember why lol! Thanks for the response, I'm gonna take another look at this page and see if I have everything needed.
Report Abuse
Post Reply Cancel
