2 years ago
Does anyone remember HAD covering a project using light reflected onto LEDs at touchless buttons?
If I recall correctly, awhile ago Hack-A-Day covered a project using LEDs as buttons. From what I remember it was either a Cornell or MIT or other major university final project. Basically it used light refllecting from the LED back onto it as a form of light sensor.
Does anyone have the link?
Separate topics with commas, or by pressing return. Use the delete or backspace key to edit or remove existing topics.
You can leave an optional "tip" with Mahalo's virtual currency, Mahalo Dollars. If you are asking a difficult question that might require some research, or if you'd like a wide variety of feedback, a higher tip often leads to more answers to your question.
M$
