tommypower's Avatar tommypower 0
1 Asked
0 Answered
0 Best
-2
No one has voted on this question yet :(
1 year, 4 months ago
How do i connect an Android tablet to LEDs i want to use in my living room? Also, how to control them via Java?
Sup Guys,
I'm a software developer who wants to bring some light to his living room via LEDs. Programming this shouldn't be too hard given the needed tools. Has there ever been some guide on how to do this? I'm not an electrician so i'd need the hardware from someone or some blueprints to get me someone to work this out.
Separate topics with commas, or by pressing return. Use the delete or backspace key to edit or remove existing topics.
You can leave an optional "tip" with Mahalo's virtual currency, Mahalo Dollars. If you are asking a difficult question that might require some research, or if you'd like a wide variety of feedback, a higher tip often leads to more answers to your question.
M$
What is Your Answer?
0
0
0
1 Answer
0
cmk's Avatar
cmk | 1 year, 4 months ago
2
Do some searches on Home Automation. There are several software projects out there, and some utilizing Java, but since you have the programming side covered, you should focus your searches on hardware. You could buy COT hardware to do what you want.
Here's a store that caters to home automation: http://www.smarthome.com
M$
Report Abuse
Post Reply Cancel
