STitus's Avatar STitus 0
1 Asked
0 Answered
0 Best
0
No one has voted on this question yet :(
1 year, 4 months ago
How might I build a rotating mount for an LCD?
I have a 23" LCD display on the way, and I intend to mount it to the wall, desk, or desktop. I would like to be able to rotate it between landscape and portrait without unbolting it from the mount every time. And most of all, I don't want to pay the price of the monitor again just for a mount!
Let's assume I already have a 100x100mm VESA mount. How might I build something to go between the mount and the monitor that could rotate? I have a few ideas, but I'd like to hear a variety of ideas before I actually try to design something.
Requirements:
Rotates between landscape and portrait relatively easily
Stays where I put it
Goes between a monitor and a mount
Easy to fabricate myself
Budget below $40 (not including my time)
Can support at least 5kg
Off-the-wall and so-stupidly-simple-I-should-have-thought-of-that suggestions are welcome! Also, if you happen to know of a commercial product in this price range, I guess that would do as well.
Thanks!
Separate topics with commas, or by pressing return. Use the delete or backspace key to edit or remove existing topics.
You can leave an optional "tip" with Mahalo's virtual currency, Mahalo Dollars. If you are asking a difficult question that might require some research, or if you'd like a wide variety of feedback, a higher tip often leads to more answers to your question.
M$
What is Your Answer?
0
0
0
1 Answer
0
rangerx52's Avatar
rangerx52 | 1 year, 4 months ago
7
use a swivel plate. it's a thin profile pair of plates, with a bearing surface on the inside, so the plates freely rotate. The weight capability is well above 5kg even for the smallest models, and they maintain a slim form factor. Just make a pair of stops on the surfaces you mount it to so that it only rotates 90 degrees and you're all set.
oh, and you can buy one from a hardware store for about 8 bucks.
images:
M$
Report Abuse
Post Reply Cancel
