candance's Avatar candance 0
2 Asked
1 Answered
0 Best
0
No one has voted on this question yet :(
1 month, 3 weeks ago
Is there another way to charge the helicopter besides plugging it into the USB port of a computer?
Is there another way to charge the mini rc helicopter besides plugging it into the USB port of a computer?
Separate topics with commas, or by pressing return. Use the delete or backspace key to edit or remove existing topics.
You can leave an optional "tip" with Mahalo's virtual currency, Mahalo Dollars. If you are asking a difficult question that might require some research, or if you'd like a wide variety of feedback, a higher tip often leads to more answers to your question.
M$
What is Your Answer?
0
0
0
1 Answer
0
electroblivion's Avatar
electroblivion | 4 weeks ago
0
USB is 5 volts from the right most and left most pins in the socket. All you need to do is get a 5 volt wall adapter from any basic household item your not using and hook up a female USB socket to it instead of it's normal end. Wiki USB for the exact pin out and how to wire it. It's not hard to do at all.
I made a device that takes any random voltage as an input and mimics a USB ports power output, to charge my ipod nano first gen. The whole circuit fits inside a motorcycle sparkplug box. Piece of cake.
M$
Report Abuse
Post Reply Cancel
