m854765852's Avatar m854765852 2
2 Asked
0 Answered
0 Best
0
No one has voted on this question yet :(
2 years ago
Is there any way to use a computer as a physical keyboard for another computer?
I want to use my laptop to control my desktop without having a physical keyboard for the desktop. That includes the ability to make bios changes, which is not possible with a software/network solution like VNC or remote desktop. I'm thinking of something like a USB device that plugs into my laptop and spits out PS/2 data into the desktop. USB-USB would also work, but not without some device in between to translate (since both the laptop and desktop want to be USB hosts, but the keyboard needs to appear as a USB device). Is there anywhere I can buy something like this?
Separate topics with commas, or by pressing return. Use the delete or backspace key to edit or remove existing topics.
You can leave an optional "tip" with Mahalo's virtual currency, Mahalo Dollars. If you are asking a difficult question that might require some research, or if you'd like a wide variety of feedback, a higher tip often leads to more answers to your question.
M$
What is Your Answer?
0
0
0
0
red_ca's Avatar
red_ca | 2 years ago
2
This was what started me on AVR micro-controller programming several years ago - building a keyboard encoder for an arcade conversion (i.e. MAME)
I'll comment on building one below, but if you want to buy one, they aren't cheap given the lack of demand.
A commercial RS232 converter is available here: http://www.hagstromelectronics.com/products/usbkm232.html
As mentioned previously, IP KVM would be the other obvious option or Synergey if you give up the bios level control.
If you want to go down the path of building one, there is a plan here: http://hobby-electrons.sourceforge.net/projects/terminal-keyboard/ using an AVR.
I will comment that the Ardunio would do this easily as well. It has all the components to become a USB serial to PS/2 keyboard. At the bootom of the page on connecting to a USB mouse (http://www.arduino.cc/playground/ComponentLib/Ps2mouse) there is a link to a PS2 device library.
Haven't done it, but I would use the stock serial interface and Serial sketch to talk to the host PC over the USB port. You would then use the ps2dev library to convert serial commands to PS2 commands. Like look at adding V-UBS module to emulate a HID, but if target PC has PS2 port, way simpler.
Good Luck!
M$
Report Abuse
Post Reply Cancel
2
southwestandrew's Avatar
southwestandrew | 2 years ago
2
The solution that you are looking for is a IP KVM switch or a remote console hardware device. These can also be installed or included a machine such as the Dell DRAC or HP LightsOut type devices. Software solutions are less expensive and still very flexible however.
The key benefit of a hardware device is that you can fully control booting on the machine and change CMOS options if necessary. An IP KVM will also emulate basic devices such as PS/2 mice and keyboards if the computer requires these to be present to boot. Many models will also emulate USB input devices. They generally require remote control of the machine via a wired (or wireless) network rather than a simple usb cable so they are more complex to setup. These types of devices can be obtained from dealers specializing in networking hardware.
M$
Report Abuse
Post Reply Cancel
2
devlinthyne's Avatar
devlinthyne | 2 years ago
3
Try out Synergy. I have used it at work and at home. It works on multiple platforms too. Open source and free. Setup how you want to arrange your screens, move your mouse from one computer to the other just as if it was a dual-screen computer. The only problem is that it will not work until the OSs have started the Synergy clients/server so keep a spare keyboard/mouse on hand just in case. If you want to be able to remote boot a machine, you could setup Wake on LAN for that machine.
M$
southwestandrew | 2 years ago Report
Wake on LAN in addition to software remote control is a good solution but video (console) redirection provided by an IP KVM allows low level hardware control (such as CMOS interaction) which can't be provided by most software solutions.
m854765852's Avatar
m854765852 | 2 years ago Report
Synergy looks like a slick solution, I'll have to try it out. It's not what I had in mind when I asked the question, but I have been looking for something exactly like it.
Back to the question I actually asked, IP KVM is close to what I'm looking for, but a quick search shows that IP KVM systems are expensive. What I'm picturing is a simple box that sits between my laptop and my desktop (in the same room, probably connected by USB) that captures the keyboard of my laptop and sends it to the desktop as if I was using a real keyboard. Maybe such a device doesn't exist, but it would be handy. It doesn't seem like it would be that hard of a microcontroller project. Even something that takes in serial data through hyperterm (or equivalent) and generates scan codes over a PS/2 interface might be good enough, and it probably wouldn't be that hard to implement.
Report Abuse
Post Reply Cancel
