anonymous's Avatar anonymous 0
57187 Asked
0 Answered
0 Best
0
No one has voted on this question yet :(
4 months, 1 week ago
Light Sensing Start to a Wireless Camera?
I have a 9volt battery hooked up to a wireless camera (http://www.amazon.com/Mini-Wireless-Color-Camera-Microphone/dp/B000YM2OIK) and I want to set it up so that when the photocell (http://www.sparkfun.com/products/9088) detects that the light in the room is turned ON the camera turns on.
Can I just wire the photocell into the wiring of the battery:
---- 9 volt ---> photocell ----> camera
Or will I "have to" make a circuit on a breadboard or something to control this?
I'm looking for simple and fast on this so if a circuit needs to be made please provide a link or clue as to a schematic I can use or reference.
That photocell can handle 150V max and in the description says "These little sensors make great ambient light triggers (when light in the room turns on, do something)."
Thanks
Separate topics with commas, or by pressing return. Use the delete or backspace key to edit or remove existing topics.
You can leave an optional "tip" with Mahalo's virtual currency, Mahalo Dollars. If you are asking a difficult question that might require some research, or if you'd like a wide variety of feedback, a higher tip often leads to more answers to your question.
M$
What is Your Answer?
0
0
0
0
adrimagnon's Avatar
adrimagnon | 4 months, 1 week ago
0
Is below the simplest I can do to accomplish what I want?
9V + -------> photocell ----> camera
4k resistor |
9V - -------------------------------------
... this was when the light is off the photocell is at 10K or so and the electricity will travel down the 4K resistor back into the battery and experience no drainage. Then when the light is on the photocell will drop to 1K resistance and the electrons will take that path across the photocell to the camera.
Will that work and is my logic and understanding on this correct?
Thanks
M$
Report Abuse
Post Reply Cancel
0
electroblivion's Avatar
electroblivion | 3 months, 2 weeks ago
0
You should try using google once in a while, Took me like five seconds to find this....
http://pcbheaven.com/circuitpages/Light_Dark_Activated_Relay/
And all I typed in was "light activated circuit schematic".
M$
Report Abuse
Post Reply Cancel
