Looking for a SMALL 12v rechargeable battery pack.
Thanks everyone!
You can leave an optional "tip" with Mahalo's virtual currency, Mahalo Dollars. If you are asking a difficult question that might require some research, or if you'd like a wide variety of feedback, a higher tip often leads to more answers to your question.
M$3 Answers
Then...
4 of these would fit inside the physical dimensions you mention, and provide 12v comfortably when run in serial:
http://www.dealextreme.com/details.dx/sku.35608
Also 3.7 volts is common for a mobile phone battery. So you could use an old phone charger in the interests of being a povey student.
If you don't require exactly 12v, then a variety of rc heli / plane batteries are available that are close enough. Eg,
http://www.dealextreme.com/details.dx/sku.37150
This particular one is 7mm too big in one direction but pretty close.
Let us know what you end up deciding on.
The voices in my head. I call the shouty one Sergeant Shouty.
M$You can leave an optional "tip" with Mahalo's virtual currency, Mahalo Dollars. If you are asking a difficult question that might require some research, or if you'd like a wide variety of feedback, a higher tip often leads to more answers to your question.
M$
