1 year, 12 months ago
Resistors and Capasitors
Can someone explain the point of and how to use resistors and capacitors? I'm new to DIY projects.
Separate topics with commas, or by pressing return. Use the delete or backspace key to edit or remove existing topics.
You can leave an optional "tip" with Mahalo's virtual currency, Mahalo Dollars. If you are asking a difficult question that might require some research, or if you'd like a wide variety of feedback, a higher tip often leads to more answers to your question.
M$1 Answer
Wow, Thats a pretty broad question, but I will try and help you as best as I can
Resistors:
Used for limiting the amount of current going through the part of a circuit. Something you may have come across is the equation V = IR where I is current, R is resistance and V is voltage.
Using two resistors you can create what it known as a voltage divider. Basically you can "chop down" any voltage you have to a lower one for use in other parts of the circuit.
Capacitors:
Used for storing charge. Their use in actual circuit design can be varied. They can be used to "store" voltage for a time where it may be needed to discharge it. In particular, timing circuits make use of a capacitors ability to charge and discharge.
I have given a very general overview of these two electronic components, what you will come across is that it is the way in which components are arranged which affects their purpose in a circuit more than the actual component. For example, A resistor and capacitor together togerther are used to form a frequency dependant signal filter.
Id suggest reading this site to start off with:
http://www.electronics2000.co.uk
It provides lots of helpful information and a few useful tools to help you along. If you have any further questions then post them and I will be happy to help.
Resistors:
Capacitors:
M$Report Abuse
